Hi.
I have problem with synchronization of Google calendar.
eM Client on Windows version 10.3.1524 (2e684e9)
Error mesage:
[Google Calendar] Synchronizace složky ‘[email protected]/Kalendář’ selhala kvůli následující chybě: Unable to cast object of type ‘System.DateTime’ to type ‘System.String’.
I Try to repair my calendar, delete and reconnect whole account, but the reason is still same.
Please help.
Thanks
This specific issue was fixed in version 10.3.1567, newer than you have now, so if you get the most recent version, you should stop seeing the error.
Thank you for your answer.
I do the version check in eM Client, but I did not get info, that the new version is accessible for download.
I had download lates version from your link manualy and synchronization still running, but it is look good I think.
Thank you very much.
