Problem with Sub folder A-Z order using the Android app
Using the latest Android app V10.3.3670 with a eg: Gmail IMAP account.
If I create a new Sub folder under a Parent folder, the app never puts it in A-Z order, and pressing my finger on the sub folder after creating “doesn’t allow me to move / reorder to drag it up or down”. Even pressing Edit at top doesnt allow that
The only way I can fix it, is to go to eM Client desktop and drag it to the right place and then close and reopen the Android app.
Needs “two options added” when you press your finger on the new sub folder to “move up” or “move down” the folder list.
If it is already there I don’t see it in the app.
