Hi Gary, - Thanks again for taking the time - You have given me the confidence to play around and am now at the following state-of-play -
Tried all of the above, which was fairly straightforward as your Names - Figures - Statements were pretty well correct - Shut-down Laptop after removing each time I removed the Account - just in case
These are the Settings shown via Tools - Accounts -
imap.plus.net Port 993 Use SSL/TLS on special port (legacy)
relay.plus.net Port 25 Force Usage of SSL / TLS
there is also a ticked box - Server requires authentication and Use Identity credentials
Smart Folder - All Inboxes show e-mails back from early January 2020
Sent - Empty, but will show a message if sent
Drafts - Began an e-mail and when closed offered Drafts - okay and can be recovered
Unread - Shows Unread messages
Flagged - shows Flagged massages from Inbox
Local Folders - All Empty
If I click on my e-mail Address
Inbox - Shows e-mails back to early January 2020
Sent - as per Smart Folder - but with a Red Triangle
Draft - as per Smart Folder - but with a Red Triangle
Every time I write an e-mail or access the Program I get the Error Box
(IMAP) Unable to create a Folder “[email protected]/Sent/” on the Server
(invalid mailbox name)
Same message for Drafts
I am currently using Windows Live mail 2012 on a Laptop destined for Scrap, and e-mails using the
same address are fine -
What I find frustrating, is the more I play around with this program, am finding it fairly User-friendly
in Options and Settings - (ie Font - Highlight - Background etc) and this Unable to create Folder is
just becoming a Pain
Hope there is enough Info for any further diagnosis -
At the moment, still able to use the soon to be defunct Laptop, so at least I know I can still
Send / Receive okay - and more importantly access any Quotes in the Sent Folder
In Hope and Anticipation -
Many Thanks again - Kevin
