i ́m testing around em client a little bit and found a problem:
I added a Carddav account (based by davical) with multiple Adressbooks - some of them are read only.
I drag n dropped a few entries from the readonly Adressbook to one of the r/w Adressbooks. Now the program asks from time to time the following question “Failed to delete Item”… look at the attached image…
Did i used the function wrong?
How can I stop the program from asking the question without deleting the entries locally?
Is there a way to tell the program not try to delete those entries - instead copy them?
This readonly Adressbook in our case should be something like a “fixed” Adressbook administrated by our secretary’s office and should always be a “full” Adressbook…
Hi, I don’t see any attached image but you can try right click the calendar folde and select Properties > Repair and click on the Repair button.
That might solve the issue.
even when you going on by “Skip Delete” and “Use this choice…” - in a few minutes you will see this question again. Is there a way changing this -obvious- “move” command to a “copy” command when usind drag-n-drop from a readonly as source?
i tried it and this workaround seem to help - but its a workaround; it would be better your drag-n-drop function should have a look if the source adrbook is readonly and not try to delete items when it ́s so…
…and I ́m also in contact with the new “main” developer of davical - he is also the developer of two of the best web-based Caldav/Carddav apps “CalDavZAP” and "CardDavMATE ".
Because there ́s maybe a problem with attachment in calendar-entries… but we have to find out first on which side the problem is located…
