Hi!
I am using eMClient v.8 with Kerio Connect.
eMClient seems to “hang” when trying to sync notes.
When you look at the current operations, the it shows:
“Synchronising folder /Notes” and does not progress from there.
The circle next to the “refresh” button on the main window spins around and never stops.
Even with this happening, mail sync still completes normally.
Any ideas?
Thanks.
Dan
Gary
April 24, 2020, 12:47pm
2
For issues with the beta, send a message to [email protected] . They will be able to assist you further.
Dan,
How did you get eMClient to even see notes on Kerio?
I’ve been fiddling with it and can’t figure out how to get it to work.
Thanks.
Cheers,
Jon
Jon
I didn’t do anything other than set up the accounts as normal using exchange active sync.
The issue I was having appears to have now been fixed.
Dan
Dan,
Are you using the Windows version? I’m using the Mac version and don’t seen an option for Active Sync.
Thanks.
Cheers,
Jon
Jon,
I was using the Windows version. However, I have become very disillusioned with Kerio since GFI took over - in particular with the fact that when I renew next month I will loose my perpetual licence.
Therefore, last week I migrated over to Office 365.
Good luck.
Dan
