Problem sync outlook calendar
Respected
it is about the interruption of the iCloud and Outlook sync calendar. All the usual settings, marked calendars for sync, however, nothing is displayed, that is, 0 kilobytes are displayed when moving the mouse over the calendar. On the web interface of Microsoft Outlook and iCloud, tasks and events are properly displayed.
Same issue here. No solution yet. I have gone to One Calendar until they sort it out.
Same problem here but using emClient on Windows 10 desktop! … my emails work fine - so like another poster I am now using One Calendar on Windows 10 and my Android phone - which works perfectly.
Same issue. No errors in the log. If I create/edit and item on outlook.com it will sync. Existing items will not. Have repaired, etc. etc.
