I am trying to import my contacts from XING (like LinkedIn) but eM Client is refusing to import from the Vcf file saying there is a “Invalid image format in the contact’s Photo (Parameter is not valid)”. What is all this about? I’m sure other clients have no problem with this file (I’ve tested in Thunderbird and had no problem)
Having imported the address book to Thunderbird, I was able to directly import it from Thunderbird to eM with no problems … but I would still like an answer to this problem.
No one?
Hi, it might be possible that Xiing does not export .vcf files in standard manner, eM Client is very strict on standards that is why it worked like you did and not directly.
I could tell you more if you would send me that file to [email protected] so I could investigate it better.
Jan
