Since leaving the update eM Client 7.0.27943.0 , stopped working the chat hosting company that is part of myASP.NET , and when trying to synchronize with chat me the message "[XMPP] Unable to access the object. Object name discarded: SslStream " , the setting remains the same as before the update but now that error occurs.
What I can do?
Hello Juan,
please copy the content of the Log tab (in the same Operations window you screenshot) next time this error pops up.
It should contain more information about the error.
Hello Olivia …
The error persists, and you associate what I appears in the log tab.
Hello Juan,
first off, try updating your Microsoft .NET Framework to version 4.6.2
If that does not help, check if your certificate is active/ valid. Have you perhaps gotten a certificate window and told v7 to not trust it?
Can you try setting the account anew?
Hi Olivia
I followed his instructions and did not work still gives me the same error discussed above, and even you uninstall and returned to install eM Client 7 and keeps going the same.
