I have 2 pro lifetime licences. One PC that had one licence on it has died, therefore I cannot access it to deactivate the licence. Therefore I cannot install on new pc. Would appreciate some help. Many thanks
jueves 07 mayo 2026 :: 2242hrs (UTC +0100)
Hey@Roger14
I am not absolutely certain, however, s your PC has given up it will have been deactivated automatically, you will find out next time you try to activate an installation.
Or you can…
Contact [email protected] and ask for help
skybat
¡Buena suerte!
Hi Skybat
Thanks for the reply. Still can’t use the licence on new pc and emclient support has been less than helpful. I’ll try them again in a day or so.
viernes 08 mayo 2026 :: 1108hrs (UTC +0100)
Hey@Roger14
Yes, sometimes they do appear slow to reply, however, usually only
at weekends and holidays.
If you have user name and passord you can use License Manager
skybat
¡Buena suerte!
Hey skybat…can’t thank you enough
. All is well now, it just took a little time for the deactivation to happen.
