Pro license for Ver 5 - downgrade from installed 6
I am not ready to spend anymore money on a license until the Calendar Timezone issue is fixed since this is a very big problem for me.
It appears that I have a Pro License for Version 5 (expires in 3 days) but I guess I upgraded to the Version 6 beta so now I keep getting upgrade messages. Is there anyway to downgrade back to Version 5 (or whatever version I have paid for) so that I don’t get these upgrade messages?
I’m sure once the calendar timezone issue is fixed I will upgrade again.
I found another post with the link: http://www.emclient.com/dist/v5.0.196… for version 5 so I have downloaded but I get a message that “A later vesion of eM Client is already installed”. Do I have to uninstall version 6 and loose all my account information?
Hi, could you tell me what issue exactly? Do you mean dismissing of Gmail events or anything else?
About that installation, you have to unninstall eM Client but your data will be kept as database has to be deleted manually.
Version you have posted should work, but you can contact me on [email protected] and I will send you link to newer 5th version.
Jan
I live in Malta (CET timezone) when I speak with clients all over the world and we set a time …say 10am PST. I can set my appointment up as 10am PST but it shows up on my calendar in my timezone. I do this on google calendar no problem.
eM Client. If I set a time for 10am PST. It shows up as 10am my time. I’ve downgraded to Ver 5 no problem and will just wait to upgrade. Thanks…
Hi, I know that this is older post but can I ask you if you have upgraded to 6th version lately without problems or do you still run on latest 5th version?
Jan
I have downgraded to 5. I can’t justify paying another $49 without the calendar fix.
I understand that, but still this issue should be solved already. So I hope that in the future if you will try 6th version again, it will be without any problem.
Jan
Thanks Jan. As soon as I can schedule calendar meetings/events in another timezone but have them show up on my calendar in my timezone I will definitely upgrade again.
