Printing is impossible - letter font is suddenly huge
I am using the latest version of eM Client on my Mac with Tahoe 26.2. Unfortunately, printing from the client is not possible because in the print dialog, the email text is formatted by the system so large that an email would span several hundred pages.
I have tried everything possible, but it doesn’t work. Is this a bug or does anyone have any advice?
Thank you in advance - Norbert
There was a vertical eg: Apple Printing bug which was fixed in a later update that might also be why thats happening for you.
So “close eM Client” and then d/l the latest Mac v10.4.4293 from the release history page and install that and see if that fixes it.
Failing that, “close eM Client” and go to Applications in Finder and “drag eM Client to the recycle bin” and then “reinstall v10.4.4293 again” incase its just an installation problem.
