What happens is that I get an e-mail from one of the discussion groups on IT Toolbox (http://www.ittoolbox.com), e.g., “pc-hardware-I”. I then reply, attaching the original e-mail. If I look in my “Sent Items” folder, I see the complete message (my reply w/ the original message). When I get the e-mail from the group, my reply is there, but everything else that was attached is missing.
Here is an example of what happened just this morning.
========= Original e-mail from “pc-hardware-l@groups.ittoolbox.com” ====
Reply from USER_2103431 on Apr 8 at 8:06 AM *sathish use below method *
*New Policies in Windows Vista and Windows Server 2008*
In Windows Server 2008, there is a set of built-in policies on removable
storage access and installation. It makes restricting USB mass storage
devices easier. To use these policies, the client computers must run
Windows Vista or later. The following policies specify read and write
permission on all kinds of removable storage devices:
Computer Configuration–>Policies–>Administrative
Templates–>System–>Removable Storage Access
User Configuration–>Policies–>Administrative
The following policy controls the installation of removable storage device:
Templates–>System–>Device Installation–>Device Installation Restrictions
---------------Original Message---------------
Sent: Tuesday, April 08, 2014 5:50 AM
Subject: Block USB drive through Active Directory
Dear all,i want to block usb flash drives through active director windows 2008 server, please anyone help. Thanks
Reply to this email to post your response.
__.____._ Manage Settings | Unsubscribe | Create FAQ | Send Feedback
Copyright © 2014 Ziff Davis, LLC. and message author.
Ziff Davis, LLC. 28 E 28th Street New York, NY 10016
====== My reply (as seen in Sent Items folder) ====================
if disabled USB mass storage device using gpedit in windows7
- Reset the gpedit configuration Set All removable storage classes :
deny all access to not configured
- Then Gpupdate
- Driver installation
Device manager -> update driver -> browse : c -> windows ->inf->
usbsstore.disabled (rename usbstore.disabled to usbstore.inf then select
usbstore.inf) -> next Finish
- Restart the machine"
My problem with this is that we use external hard drives a lot.
Hank Arnold
------ Original Message ------
To: “Hank Arnold”
Sent: 4/8/2014 8:34:09 AM
Subject: Re: [pc-hardware-l] Block USB drive through Active Directory
Reply from USER_2103431 on Apr 8 at 8:30 AM if disabled USB mass storage device using gpedit in windows7
- Then Gpupdate
Sent: Tuesday, April 08, 2014 8:21 AM
I want to through ad and most of my client system running windows7
enterprises.
===== This is what is posted in the group ====================
Question from Hank Arnold on Apr 9 at 4:10 AM "if disabled USB mass storage device using gpedit in windows7
- Then Gpupdate
Hank Arnold
