Occasionally an error popup message appears, that says: “too many active sessions”. This message stays on top and prevents further email processing.
Till i press “cancel” no further emails will be processed.
Is there a possibility to ignore all those errors to keep the emclient productive without interaction?
av / firewall is an idea, but i cannot disable it for maybe 24hours to see the difference.
and especially for email - a av solution is very usefull ;-).
I only need an idea to disable error popups. Is there no registry tweak or something?
Can you check that the same account is not installed more than once in Menu > Accounts.
Otherwise, as this is an error from your server saying that there are too many connections, is it possible the same account is also installed in other email applications or on other devices?
