Hey Everyone,
I am having an issue where sometimes my pinned messages are becoming unpinned when I do something else to the message like flag it or set a tag. Has anyone seen this? I think it might be a sync delay issue or something. I can upload a video of me reproducing it if that helps. Thank you!
–Scott
No i am not getting any automatic unpinning personally with the latest V11
First check you have the latest V11.0.1267 on PC or Mac incase you have an older version. If you don’t have that version and you originally downloaded eM Client from the website then go to the release history page and download and install the update and see if that fixes it.
If you already have that version, then could be you might be accidently pressing shortcut keys to unpin email.
Shortcut key to Unpin Windows
Shortcut key to Unpin Mac
Next if you are not accidently pressing shortcut keys then “if you are right clicking on the email” to flag or tag, you could be accidently unpinning emails with your mouse.
Hey there! I am definitely on 11.0.1267. I am not accidentally hitting the shortcut keys unfortunately.
OK, I think I might have figured out what is happening. I have a PC at work and a PC at home both running 11.0.1267 withe same Microsoft accounts. I also have emCLient installed on my phone with the same accounts. This is unpinning when a sync occurs. I bet this is because I have multiple PCs running this.
Here is a little screen capture of it happening:
If I do this enough on the same message sometimes it will stick, but then some time later some of them get unpinned again after another automatic sync.
Thanks,
–Scott
If your refresshing and emails are automatically unpinning & you have an IMAP, Exchange, Office365, Graph or iCloud account, then that usually means “another device has already unpinned that email and synced that unpinned status to the mail server” which then will automatically unpin on all your desktop clients.
So are you unpinning on any of your other devices ?
I am not unpinning from other devices. I only use 1 device at a time here. This is most likely the issue though with how it is syncing. What is interesting is that message flagging works perfectly fine and works great across devices.
I really love the idea of being able to pin messages, so hopefully we can get this working reliably for me! Thank you!
–Scott
Suggest then as nothing is making any differance and its still happening, to contact offical support who can investigate that further for you. So if you have a current paid active Pro, Personal or Business license, go to the VIP Support page and login and lodge a support ticket and link this thread so they can see your video example of the issue & whats already been suggested.
