PIN set-up
Exporting via a QR code requires a PIN. A PIN was never set up and the instructions for re-setting a PIN are incorrect
The instructions:
Settings>Accounts>Sign-in options>
Do not exist
I’m using vrs 10
Any advice?
It is your Windows OS PIN.
Good to know. Thank you much.
