I use the Windows snipping tool to copy an image to the clipboard and then paste it into the body of an email. Problem is that email is rejected by all recipients as spam due to the png format of the paste. How can I fix this?
Pasting an image inline wouldnât normally cause it to be rejected on the receiving mail server unless it has a eg: complete block on html emails with images and only allows text.
Whatâs the actual error you are getting bounced back ?
âYour message wasnât delivered because the recipientâs email provider rejected it.â
"Remote Server returned â550 5.7.520 Message blocked because it contains content identified as spam. AS(4810)â "
Every message I send with a PNG paste from clipboard is rejected.
I cannot replicate that same problem you are having. Using eM Client V9.2.1222 for Windows i can send emails with pasted .png files via the clipboard into and email body directly or attached and they are not rejected on any mail server i send to including Gmail, Microsoft, Yahoo & a local ISP etc.
So from the error you are getting 550 5.7.520, either you have some eg: http:// or https:// or other code in your email being sent out, or your email address or your mail server ip address has been identified as sending spam in the past and the receiving mail server or servers have blocked you for some reason.
So first right click on your email with the .png pasted in it and then click âview sourceâ and see if you have any http:// , https:// or any other links. If there is, delete them and try sending your email again.
Also if you have any eg: âSignaturesâ in eM Client setup with links or email addresses etc in the body, try removing those as could be something in there might also be causing an issue on the receiving mail server end and being marked as spam.
Failing that if you donât have anything in the source code and no signature setup that might be interfering, then you will have to contact the technical support at each receiving mail server to see why your emails are being rejected.
Sometimes receiving mail servers have eg: a very aggressive spam policy and it could be they are not allowing certain content, apart from blocking specific email addresses or mail server ip addresses etc.
I just tried it again sending to myself and it was again âundeliverableâ When I check source as you suggested the result is huge!!
You can copy the source code out into a text editor such as eg: Notepad (Windows) or TextEdit (Mac) and then search / look in that.
Any http links, email address @ links or ip address (number x.x.x.x links) where you can be rejected & need to search / look for, will normally be âat the top partâ of the source code.
The .png image part will normally be âdown further in the source codeâ as in my example below with alot of stuff underneath that. So you wonât need to worry about the .png / image part of the code.
(Example .png / image part of the source code which you would normally ignore)
â=_4a4c65fb3c8e5b2fa053a6468e378fbf
Content-Transfer-Encoding: base64
Content-ID: 1671258879639d62ff86af7175693133@mydomain.com
Content-Type: image/png; name=51cdd309.png
Content-Disposition: inline; filename=51cdd309.png; size=1300878
iVBORw0KGgoAAAANSUhEUgAABC4AAALwCAYAAABYyzTDAAAAAXNSR0IArs4c6QAAAARnQU1BAACx
jwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAP+lSURBVHhe1L1ZkyVHlt/nud7c9732AlBYu4Hu
RvcszRmSMyMOZRQp6kFGGvXEb6LPIX4EmV4oMw1JyUQTx8SZ7plegG6sBRRQW+7bzX1P/X//E+fe
yEQB6OY0H+SZfiPCw8P9+PHjZ3MPj45LhfKbhszZEYerD14q+bxsNVfLL977aXn/g78tR2c7ZXC0
p5xcHJSdg82ys7dZOrsuS29vw3Ggf6AMDY2Ug4Oj8vzZUunpaZSe7r7S2dmjsrpKd3ejDA2OlMHB
4dLT6C2Hx/uKB+Xk9LQA9vHxUdnfPygXF5d6trsc7O+Wzo4LxbPS29NVRkeGy9TkZBkZGlW9veVv
f/ZeOb8wqKWjo6OcnZ2Xo6NjHwnn5+elq6urzM3NloGB/rKz0yxd3V2qf7CcHlPmQGn09pdTFbK9
I1iOTsv5ZXfZ3T8pW9v75eSklNOzy3J6Snkdpa+vrzQE98X5aTk6OSin5aR0dpcyoLTR4cEyPjwg
2PpLo0sgnZ2W9dXlcq62AUNXlzIKRvDUoeuDw8OyurFRxibHVfd26entLb19wldPb5mcmiobG1tl
TzD1N/pKh/Cxt7NTjg8OSk+nyhAu6KvL7u7S6B8sgwNjKrNRmvvHZaO5q34SvN3CueKZ2tah3I3u
ztLfo77qOC2NTrVd4JxfnAjXZ3pefddolMsLPQfuhaPLy4ty2XFZVtdXwKRwNqB+7C6D/cPqwzHj
5EJ00z8wpPOLsrnRLIeHx8L5hXDUIzroV1HHqvlUuNwoI+q7V199rbzy8oMyOjpeVlZWytbGqsrt
E87P1e976rsjlQW+utVfpJ8KZ+fqF7X9+JAW67pTOOxX+cPCh+hld09o7TTeztxPpfT1N0RrXWob
15eC6cz0Qb7j4xOXPz4+Uvb2NkRTQ+4T+re3t099e6l+jz5rgJNqOPFsZycd26m0DrUNWC7KoPq8
R/0B7Z6oz6H37q6BcnHWUN/3l8Xne+X9X3xZ1laPyvjoTeG4UZaXNsoO/STap72mV+H9QvR6qShQ
VUZH+eG73y//8l/+i/JXf/3/ln/zb/6X0t8PDe+aDjsEg7rFQT1hHF52Xuq5S420s9Klvh3pFayH etcâŚ
