Gibt es eine Möglichkeit das Mailkonto Passwort sichtbar zu machen bzw. auszulesen ???
I do not believe there is a way to display or verbalize the password, in eMC.
Perhaps there is a way to do that on your email host, via webmail. If you use a password manager, it might have the information you are looking for else you might want to give some thought to installing one (Bitwarden is my preference).
