Overnight Calendar Capabilities
My work day begins at 4pm Eastern and ends at 1am Eastern. The calendar does not allow to start at a PM and end in an AM. There should be a way to do this in eM Client. Outlook implemented the ability to assign multiple work hours per day to overcome this limitation. Say…
Monday 4pm EST - midnight EST
Monday midnight EST - 1am EST
I believe this is something that should be addressed if eM Client wants to really provide an alternative to Outlook.
You can set the “Work week” in the “Settings / Calendar / General” section to start at PM and end at AM as per the below screenshot. Have you tried that already ?
That doesn’t work.
I don’t get that same error when i enter those times and save settings as in your screenshot.
What version of eM Client are you using ?
10.0.3266 (7060eea)
Screenshot 2024-07-27 231750
Ok try the latest release 10.0.3351 via the release history page. Close eM Client before updating.
https://www.emclient.com/release-history
Same result.
Screenshot 2024-07-28 002704
Ive just tested the latest version and its now doing the same as yours on the PC and Mac. So sounds like eM Client devs would need to do an update to allow that.
