Just installed em Client, I have been using my ole Outlook 2010 client to pick up my Gmail account.
Following installation Em Client downloded all of my Gmail messages but I have all of my oranizational folders in the old 2010 Outlook client. how can I make Em Client duplicate the folders in the Outlook client?
Thank you
How can I make Em Client duplicate the folders in the Outlook client?
Sounds like you had “custom local folders” setup in Outlook 2010 and not kept in folders / labels directly under your actual Gmail account.
So if you have V10 eM Client, you would first “export your Outlook mail store messages to a .pst file”. Then in eM Client click “Menu / Data Files” and you can then import your Outlook .pst file into a custom folder of your choice.
The Outlook imported .pst messages will then show "below your email accounts on the left in an eM Client (.emdf) message store data file.
See eM Client documentation on Data Files
You can then “drag or move” the imported Outlook folder messages to wherever you like under any email account.
Or alternatively after importing, you could “leave those messages in the .emdf data file” to be accessed anytime.
Or you could move those imported messages to “Local Folders” at the bottom left.
