I am new to eM Client and I am finding it difficult.
I am used to Outlook 2010 and eM Client seems to be quite similar (I like folder based things), unfortunately, after importing Outlooks .PST files I can’t see my Contacts and Calendars. I can see a folder that says Contacts but there are no contacts to view and there is no other folders to choose from can you help?
I am using eM Client 8 and, being an older member, I didn’t grow up with computers.
I have attached a print view shot of my Contacts folder.
Go to Menu > Settings > General, and tick Show Local Folders.
Then in the calendar and contacts section, make sure the Local Folders Contacts/Calendar is ticked and you have highlighted the section as in this screenshot:
I’ve looked at Menu > Settings > General > Show Local Folders and it is already checked, but just to make sure I unchecked it, saved changes and then rechecked it and saved changes again to put me back to square one.
Looking at your image I don’t see Gmail or Local folders just the one Contacts folder which is empty
SORTED but slightly different from your instructions. This is what I had to do;
Menu > File > Import > choose .PST > Next > Select PST file and Open > Next > Under Importing drop down menu uncheck all but the Contacts folder > Next > choose Import data to a specific folder > Select the folder Contacts > OK > Finish.
