*I created an operation that did not work and have not been able to get rid of it. Can anyone tell me how to delete an operation?
What do you mean by “operation”? Did you mean a rule?
On the “menu” drop down menu there is an entry called operations. THis is the message I receive on startup.
[CardDAV] Creating or updating folder ‘/Contacts’ failed due to the following error: Cannot create folder “Contacts” due to the following error(s): Server Error (InternalServerError).
Will attempt to create folder on next synchronization.
