I have recently starting using eM Client however when I open the program it is forcibly opened into full screen mode (ie the windows task bar is not visible)
How can I stop this happening?
I’m not sure how you got it to full screen, as I wasn’t aware that was even an option. Can you get it out of full screen at all? eM Client will open in the state it was last closed in.
eM Client does not have a full screen mode, but what could be happening is that the taskbar is set to automatically hide. You can see if this is the case by moving your mouse off the bottom of the screen. If the taskbar is set to hide it will reappear. Then just right-click on the taskbar and choose taskbar settings and disable the automatic hide option.
Another cause may be that some desktop tweaking application is responsible.
