i have uploaded this image of the error message i keep receiving when i start the client up.
Hi Elliott, this unfortunately points to a server issue, however it seems like your server does not accept a message you’ve deleted in eM Client, you should be able to resolve this issue by using the repair function on the “Trash” folder referenced in the error.
Right click the folder and select Properties > Repair and click on the Repair button. You should also be able to resolve the issue by deleting the single message mentioned in the error.
Paul
