The error says the destination folder is not found. When I check the rule the destination folder is gone.
What version do you have? If lower than 10.4.4209, please install that one. It should address your issue.
https://www.emclient.com/dist/v10.4.4209/setup.msi
Same problem with Version 10.4.4195 (7d32f97)
Have you tried the suggested version 10.4.4209?
10.4.4209 resolved the problem. Thanks!
