No texteditor for Contacts in database (.emdf)
  • Em Client: 10.4.5642
  • OS: Windows 11 Pro for Workstations, Build 26200
I was glad to see that text for Notes field in the Contacts were imported from Oulook Classic to eM Client with the text format intact. Very good! :slight_smile:
But, if i import to an .emdf database the formatted text goes away if/when i edit the text. However, if either import or move the Contacts to Local folders everything works as expected, iow that i can edit the text without loosing the formatted text.
I noticed that text formatting, etc is aviable when contacts are in the Local folders but non-existent if the same Contact are in the .emdf database.
I will use .emdf databse, so it is important for me.
  • Why is that, iow no text editor if a Contact is in an .emdf file?
  • Any plans for text editor for .emdf databse Contacts?
