Just switched to eM client and all was grand. All emails transferred over from Thunderbird and all test emails worked. Then a dead stop on receiving emails. Still can send, but constant error messages trying to receive. Ran through diagnostics, which “fixes” settings each time, only to be disappointed when testing once again. NO EMAILS CAN BE RECEIVED. When I look at my email on the web-browser, they are received. Issue seems to be dialog between eM Client and server. Settings for server should be:
When setting up:
- POP - choose POP and the incoming server port will default to 110
- IMAP - choose IMAP and the incoming server port will default to 143
- All other settings are the same.
Note - Substitute your actual domain name for “yourdomain.com” and substitute the first part of your email address for “user.”
- Username = [email protected]
- Password = the password you set up when you configured your mail box
- Incoming Mail Server = mail.yourdomain.com
Outgoing Mail Server = smtp.yourdomain.com
- Outgoing Server Requires Authentication (typically found in advanced options or settings)
- Do NOT check “Log on Using Secure Password Authentication”
- Use the same Username and Password as Incoming or select “Use Same Settings as Incoming”
Outgoing Server Port = 2525 or 587
- This is subject to change based on the individual preferences of your ISP
Note - Make sure you are not chosing and SSL type, this option should be turned off, or “None” should be selected.
