hey ho!
It´s not possible, to send or receive any e-mails…
I only see a red triangle with a exclamation mark… the connection to the internet is
working… what can happen?
Update: Send is possible, but no download …
Thanks a lot!
hey ho!
Thanks a lot!
lunes 21 septiembre 2020 :: 1301hrs (UTC +01:00)
Hi Peter…
Sorry you are having a problem, just a few questions:
1./ What version of eM Client do you have?
2./ Is it Free or Pro?
3./ Who is your ISP? (email provider)
4./ Do you use IMAP or POP3?
Russ
Hello Skybat, thanks for your answer!
Meanwhile, I repaired the IMAP connect by diagnostic functure
Now it works, thanks a lot for your support!
Greets, peter
