The default folder names that EM client uses and the default folder names that my IMAP server uses are different, as
a result I have two folders of each type that are used for the same purpose.
EM client= Junk E-mail
My server= Junk Mail
EM Client= Draft
My server= Drafts
The Inbox, Sent and Trash folders are the same on both my server and EM client but my server does not allow me to change a default folder name to match EM client and EM client does not allow me to change a default folder name to match my server, the result is extra folders cluttering up things in addition to having to manage four folders when their should only be two folders.
If I could re-name the EM client default folders to match my server default folders it would be nice and resolve this issue or at least map one folder to another and then make it invisible. My server allows me to re-name the EM client folders but when I attempt to make them match the server folders (rename “Junk E-mail” to “Junk Mail”) my server indicates that it will not allow two folders with the same name, also I suspect EM client will not be happy if the server re-names its default folders that appear to be locked.
Was not obvious when I searched but you would think that current IMAP standard (rfc3501) would specify default folder names so this issue resolves itself.
