My rule not working
@Tim_Farnden
Mail is automatically going to junk with no rule setup, but it has been happening since spam was invented! Just recently it has become an epidemic (my mail address is obviously out there somewhere) with 40-50 per day from different email addresses/domains. As there is always the possibility that there may be a genuine mail in there then I have to check them all several times a day.
My email provider is microsoft Live.
Apart from what @rocky & @BigR advised above, if you want to alt try setting up rules or a whitelist at the Live.com Microsoft online to block senders & keep only the senders you do want see the following links. Then all your devices will be the same as its done at the server end.
Manage email messages by using rules in Outlook
Add recipients to the Safe Senders List in Outlook
Thanks both.
To start with the easiest: yes, I add genuine senders to the whitelist when I find them in Junk.
Secondly, am I correct in my assumption that outlook.com is essentially a client for the email service in the same way that emc is?
If so then emc doesn’t get its emails from Outlook.com it gets them from the microsoft email servers that serve any client that has access to it. Consequently setting rules on Outlook.com won’t effect mails being delivered to emc, only emails being pulled down by the Outlook.com client.
What I need to do is turn off spam detection on the Microsoft servers (not on outlook.com) so that all email is delivered to my emc inbox. (As far as I know that can’t be done). I can then apply filters there. I appreciate that may become too much hard work but it would give me control.
I suppose a way to tell is turn off/pause your Rules in eM Client and if new emails appear in the trash or spam, it is coming from Microsoft and none of your rules will work as it bypasses the Inbox in eM client?
Hi @rocky, yes, that is exactly what I am doing at the moment. I have no rules in emc and no rules in Outlook.com and my emc Junk folder is filling up.
If we could have rules in emc that work on the Junk folder then the problem would be solved regardless of the mail provider.
This does not solve your problem, the email provider moves the mails, that has the higher technical priority.
Yes, it would solve the problem. If I could apply the rule “words in subject/body -delete permanently” to the Junk folder then they would disappear as soon as they hit the Junk folder.
Ultimately the email provider decides what mails are in what folder, its not a decision up to emClient.
Sorry, I’m not explaining myself clearly. We have established that the email provider is marking the emails as spam and emclient is therefore feeding them into the Junk folder when it pulls them down from the provider’s server.
As we can’t stop that from happening then a rule in emc to delete anything in the Junk folder with keywords in should work. They would effectively enter the Junk folder and be deleted immediately.
Sadly, emc does not provide the ability to run rules on the Junk folder currently.
I see a difference in POP3 and IMAP. In IMAP the files are stored by the provider.
You can actually run the filter manually and select folders at that time. So could run them manually on Junk Folder. I was waiting for my Scotia ones to come in to try.
Thanks @rocky. That does work.
If I could use the rule to look for the keywords in displayed email addresses as well (i.e. Casino 4 You. That is the address that is displayed but the actual address is a string of numbers) that would get rid of more. There is no option to do that.
