My E m client window closed suddenly. When relaunching the program a window opens and check the data but during the checking the data, it reports that the data check fail and the program does not start.
I am getting the error message as under
"eM Client (6.0.21040.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 2.0.50727.5477
System.Data.SQLite.SQLiteException: database disk image is malformed
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at MailClient.Storage.Data.SQLite.DbRepository1..ctor(Compactor compactor, String indexTable, String[] readWriteDatabaseNames, String[] readOnlyDatabaseNames) at MailClient.Storage.Data.DbCategoriesItemRepository
1…ctor(Compactor compactor, String indexTable, String[] readWriteDatabaseNames, String[] readOnlyDatabaseNames)
at MailClient.Storage.Data.SQLite.DbMailRepository…ctor(Compactor compactor)
at MailClient.Storage.Data.RepositoryFactory.get_MailRepository()
at MailClient.Storage.Application.Folder.CreateMailItemsCollection()
at MailClient.Storage.Application.Folder.get_MailItems()
at MailClient.UI.Controls.controlMailFolders.AttachUnreadCallbacks()
at MailClient.UI.Controls.controlMailFolders.AttachCallbacks()
at MailClient.UI.Controls.controlFolders.LoadNodes()
at MailClient.UI.Controls.controlFolders.OnLoad(EventArgs e)
at MailClient.UI.Controls.controlMailFolders.OnLoad(EventArgs e)
at System.Windows.Forms.UserControl.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at MailClient.UI.Forms.BaseForm.WndProc(Message& m)
at MailClient.UI.Forms.BorderlessForm.WndProc(Message& m)
at MailClient.UI.Forms.formMain.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at MailClient.Program.b__4()
at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action1 handler)<br><br><br><report xmlns="<a href=" http:>" rel="nofollow" target="_blank">http://emclient.com/ns/report">;<br> <product><br> <name>eM Client</name><br> <version>6.0.21040.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 6.1.7601 Service Pack 1</osversion><br> <frameworkversion>2.0.50727.5477</frameworkversion><br> </environment><br> <exception><br> <type>System.Data.SQLite.SQLiteException</type><br> <message>database disk image is malformed<br>database disk image is malformed</message><br> <source>System.Data.SQLite</source><br> <stack><br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663598</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Reset</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>83</offset><br> <nativeoffset>282c3</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663597</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Step</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>3c</offset><br> <nativeoffset>f0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663982</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>NextResult</name><br> <parameters></parameters><br> </method><br> <offset>12f</offset><br> <nativeoffset>154</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663943</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>cmd</name><br> </parameter><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behave</name><br> </parameter><br> </parameters><br> </method><br> <offset>5d</offset><br> <nativeoffset>7a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663757</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteReader</name><br> <parameters><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behavior</name><br> </parameter><br> </parameters><br> </method><br> <offset>c</offset><br> <nativeoffset>26</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663760</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteNonQuery</name><br> <parameters></parameters><br> </method><br> <offset>6</offset><br> <nativeoffset>27</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100670279</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbRepository
1
.ctor
MailClient
MailClient.Storage.Data.Compactor
compactor
mscorlib
System.String
indexTable
mscorlib
System.String[]
mscorlib
System.String[]
a2
1cf
MailClient.exe
100670326
MailClient
MailClient.Storage.Data.DbCategoriesItemRepository`1
.ctor
MailClient
compactor
mscorlib
System.String
indexTable
mscorlib
System.String[]
mscorlib
System.String[]
0
4e
MailClient.exe
100685656
MailClient
.ctor
MailClient
compactor
0
a9
MailClient.exe
100686184
MailClient
get_MailRepository
1a
87
MailClient.exe
100677181
MailClient
0
17
MailClient.exe
100677180
MailClient
get_MailItems
1a
27
MailClient.exe
100678772
MailClient
12
53
MailClient.exe
100678771
MailClient
AttachCallbacks
0
4
MailClient.exe
100678607
MailClient
LoadNodes
98
16b
MailClient.exe
100678604
MailClient
OnLoad
mscorlib
System.EventArgs
e
53
99
MailClient.exe
100678765
MailClient
OnLoad
mscorlib
System.EventArgs
e
0
d
System.Windows.Forms.dll
100688067
OnCreateControl
6
26
100668626
CreateControl
mscorlib
System.Boolean
fIgnoreVisible
bf
180
100668626
CreateControl
mscorlib
System.Boolean
fIgnoreVisible
92
129
100668626
CreateControl
mscorlib
System.Boolean
fIgnoreVisible
92
129
100668626
CreateControl
mscorlib
System.Boolean
fIgnoreVisible
92
129
100668626
CreateControl
mscorlib
System.Boolean
fIgnoreVisible
92
129
100668626
CreateControl
mscorlib
System.Boolean
fIgnoreVisible
92
129
100668626
CreateControl
mscorlib
System.Boolean
fIgnoreVisible
92
129
100668625
CreateControl
7
23
100668983
WmShowWindow
System.Windows.Forms.Message&
m
42
97
100668986
WndProc
m
5b1
2b5
100669461
WndProc
m
3a
29
100669568
WndProc
m
13
f
100679192
WmShowWindow
m
11
40
100679197
WndProc
m
222
153
MailClient.exe
100667212
MailClient
WndProc
m
86
c6
MailClient.exe
100674591
MailClient
WndProc
m
6ec
bee
MailClient.exe
100693062
MailClient
WndProc
m
23
2a
100669170
System.Windows.Forms.Control+ControlNativeWindow
OnMessage
m
0
f
100669173
WndProc
m
8e
30
100669134
DebuggableCallback
mscorlib
System.IntPtr
hWnd
mscorlib
System.Int32
msg
mscorlib
System.IntPtr
wparam
mscorlib
System.IntPtr
lparam
25
56
100683798
ShowWindow
mscorlib
System.Runtime.InteropServices.HandleRef
hWnd
mscorlib
System.Int32
nCmdShow
ffffffff
0
100668898
SetVisibleCore
mscorlib
System.Boolean
value
3e
332
100679006
SetVisibleCore
mscorlib
System.Boolean
value
8c
86
100668499
set_Visible
mscorlib
System.Boolean
value
0
10
100668201
System.Windows.Forms.Application+ThreadContext
RunMessageLoopInner
mscorlib
System.Int32
reason
System.Windows.Forms.ApplicationContext
context
92
e7
100668200
RunMessageLoop
mscorlib
System.Int32
reason
context
13
60
100668126
Run
context
0
Hi, this unfortunately seems to be a database corruption issue, some of the database files are no longer accessible or are corrupt and thus can not be read by the application.
Do you have any local data in your current database location?
In order to access your accounts you may have to setup a new database by navigating to your local folder > App Data > Roaming, and rename or remove the eM Client database folder from this directory.
Next time you open the application, eM Client should automatically create a new database.
Paul
Hi!
I am using Window 7. O/S Where will be the Local Database file/folder.
How can I find the Data base Location to rename the same.
Hi again Sanjay, as I mentioned in the previous comment, your current database is located in the local folder on your computer under the App Data/Roaming folder. Rename or remove the current “eM client” database folder and reopen the application to setup a new database.
Paul
