Would love to use multiple Smart Folders in a “single pane of glass” for daily email usage. Sort of like Groups are used to break up the sort order, be able to have something like below?
Bonus points for being able to customize the headers either with font color/size and/or the displayed text.
Double bonus points if you allow each header to override the “use color of tag as text color” so to effectively hard-code that single pane of glass section colors regardless of how it’s used elsewhere with the normal config.
-------------- HEADER 1 -----------------
emails from smart folder 1
-------------- HEADER 2 -----------------
emails from smart folder 2
