MS365 - GRAPH - kalender sync problem - entry deletion
Hello everybody,
I have the latest EM11 (11.0.1267 (ca9fa42)) running.
There had been a problem with an MS365 entry, and it looked like a duplicate. Deleting it caused this:
[Microsoft Graph] Löschen von Elementen in Ordner ‚xxx 365/Kalender’ fehlgeschlagen mit folgendem Fehler: The send or update operation could not be performed because the change key passed in the request does not match the current change key for the item.
The full log is this:
11:03:23 xxxx 365 [Microsoft Graph] MailClient.Storage.Application.OperationException: Löschen von Elementen in Ordner ‚xxxx 365/Kalender’ fehlgeschlagen mit folgendem Fehler: The send or update operation could not be performed because the change key passed in the request does not match the current change key for the item.
—> Microsoft.Graph.Beta.Models.ODataErrors.ODataError: The send or update operation could not be performed because the change key passed in the request does not match the current change key for the item.
at Microsoft.Kiota.Http.HttpClientLibrary.HttpClientRequestAdapter.ThrowIfFailedResponseAsync(HttpResponseMessage response, Dictionary2 errorMapping, Activity activityForAttributes, CancellationToken cancellationToken) at Microsoft.Kiota.Http.HttpClientLibrary.HttpClientRequestAdapter.SendNoContentAsync(RequestInformation requestInfo, Dictionary2 errorMapping, CancellationToken cancellationToken)
at Microsoft.Kiota.Http.HttpClientLibrary.HttpClientRequestAdapter.SendNoContentAsync(RequestInformation requestInfo, Dictionary2 errorMapping, CancellationToken cancellationToken) at Microsoft.Graph.Beta.Users.Item.Events.Item.EventItemRequestBuilder.DeleteAsync(Action1 requestConfiguration, CancellationToken cancellationToken)
at MailClient.Protocols.MSGraph.MSGraphEventItemSynchronizer.Delete(IItemDeleteContext1 deleteContext, Folder folder, IEnumerable1 items, CancellationToken cancellationToken)
at MailClient.Protocols.Common.ItemSynchronizer`2.<>c__DisplayClass35_0.b__0(WorkerStatus status, CancellationToken cancellationToken)
at MailClient.Protocols.MSGraph.GenericMSGraphCommand.Execute(WorkerStatus status)
Exception_EndOfInnerExceptionStack
AccountId = null
AccountName = null
RunInPlace = False
“clicking” on ignore button does not help. it is happening with every MS sync.
Also no other MS365 calender sync is possible anymore.
Anybody encountered this, too?
