MS teams invite not added to calendar
When we receive MS teams invites and accept, the response is sent, but no event is added to our (google) calendar.
Some more info:
  • Other invites are added to the calendar without issue, including invites with online meeting links, the problem only occurs when the invite was sent from MS teams directly.
  • If we accept the same MS Teams invites on another device (e.g. iphone) the event is added to the (google) calendar.
  • The only difference between the invites that we can see in Emclient, is that there is no invite.ics attachment for the MS Teams invites.
  • We have had this problem for a while and updating Emclient has not helped.
Great if anyone has any idea what is happening and how to fix it!
Same problem. MS teams invite not added to calendar.
If the account the invitation was received on has its own calendar, then the event is created in that calendar when you accept it.
If the account doesn’t have its own calendar, then the event is created in the Local Folders calendar instead. If Local Folders calendars are not visible below your other calendar folders, you can enable them by selecting Menu > Settings > General > Folders > Local Folders. Click on Save & Close to save the setting.
MS teams invite are added to Local Folder despite my account have it’s own calendar account. How can I tell eM Client to not use Local Folder but the Google Calendar of the account?
In the settings, you can search for local calender. Then disable that it is shown.
