MS Bookings calendar - not recognised in eM client
The M365 Bookings app creates calendar entries on my M365 calendar (online, on win10 and on android), but not on eM client. Could you please advise? Is this not supported on the eM client calendar functionality?
More perplexingly, if I import the Exchange calendar as a CalDAV (.ics file) in eM client, the MS Bookings entries show up in eM client like all other exchange calendar entries. But in that case they won’t sync.
… and to continue the perplexity, when I import my Exchange calendar to google calendar, the MS Bookings entries again show up in google calendar like all other exchange calendar entries. But not on eM client.
I think I got the same issue
Did you find a solution in the meantime?
Cheers, Bert
I read somewhere online that Bookings meetings sync with third party calendars that sync on Exchange Active Sync (EAS), but not on Exchange Web Services (EWS). And the eM client calendar syncs on EWS.
But then I created a shared bookings page on MS Bookings. This syncs fine.
Yes, that’s crazy.
I had also read something like that.
But I couldn’t reproduce it for sure either.
It is also strange that appointments created with the bookings company page work.
Only appointments created with myBookigs have the problem.
For me, this is a clear problem on the part of MS. MS Support disagrees because it is displayed correctly in Outlook. - So, it’s a problem to the 3rd party application.
As a customer, I am caught between chairs.
That app might not then be fully supported by eM Client. Suggest to find out, if you have a current paid Pro or Personal version to go to the VIP support page and login and lodge a support ticket.
Normally if you add a MS365 account into eM Client it will sync whatever calendar info you have online “the same to the desktop and the mobile app”, but as it’s not, then could be some settings you need to adjust within the eM Client account. So official support can advise you on that.
