I was using eM Client on Windows 10. I have since moved to Linux Mint 20.3. I installed eM Client 9.0.1708 in Wine 7.0 and it seemed to be running fine. Then I tried to transfer over my configuration from Windows to Wine. And it started crashing repeatedly.
I don’t need to bring all of my email over. It can download again. What I want is just the configuration that I set up for the eM Client app.
Are there just certain files that I can transfer over to set my theme and other preferences without having to bring over the entire database?
You normally would need everything in the existing eM Client database to have exactly the same config when opening on another computer.
There is also no Linux support from eM Client on this forum, so we cannot guarantee anything will work 100% even if you transferred all the stuff over to Mint under Wine.
I understand about the Linux support.
But thanks, I guess I will just need to setup from scratch.
