It would be great if we could create more complex rules, such as including “any one of” in the ‘from’ to capture different correspondents in one rule. It would also be good if instead of a whole email address, we could include a domain, e.g. *.myclient.com
I find I have to create two rules quite often - one for mail from someone and another to someone.
Also, It would be fantastic if there were a way of right-clicking on an email or contact or email address and have an option to ‘create a rule from’ whatever we’ve clicked.
thank you for your reply!! Can’t believe I’ve missed this. The create rule from is currently quite limited, as you need to be in the open email: you can’t right click on anywhere that you see an email address. I would most usually use this from the email list, rather than from within an email.
interestingly the check for updates didn’t find any updates, but I was one behind. I’ve updated to the latest and it hasn’t changed the rules to give that dropdown. Is it mac only at this stage?
Is it possible to create a rule which makes tagged emails move to a designated folder? Preferably applicable to a set of different tags?
I’d highly appreciate.
Thx,
Seppe.
Unfortunately not. When a messages arrives at your server, it shouldn’t have any tags. eM Client Rules only apply automatically to new messages as they arrive, so the tag option would not be a consideration.
