@Michael_Premo
When I close eMClient my monitors blank out, simulating power off/energy save… After they complete their “blank”, moving the mouse “wakes” the monitors back up. (Just like Control Panel/Power Plan/Turn Off Display after X Minutes…).
Problem started somewhere around last update or the update before. Didn’t note it at the time.
eM Client updating in Windows wouldn’t normally make any difference.
As long as emClient has been open the requisite amount of time, switching to a new theme causes the screen blackout blanking issue.
I personally carn’t replicate monitor screen blanking with any eM Client theme or community user theme after exiting / closing eM Client Windows 10 & 11 running resolutions of eg: Full HD, 2K and 4K. I don’t have 8K to test that. Others on this forum who do can advise on that.
However as you do have this blanking issue exiting eM Client, then “if you originally installed eM Client directly from the website”, try downloading the latest V10.3.2619 for Windows via the release history page below link, and see if that makes any difference as there was updates recently for specific dark themes.mainly though only with message rendering and not this issue.
Note: Close eM Client before updating and also make a manual backup via “Menu / Backup” before updating in case you need to restore for any reason. You can see when the backup is complete in Show Operations via clicking the drop-down on the right of Refresh top left.
“eM Client release history page”
https://www.emclient.com/release-history
Now if the latest V10.3.2619 update makes no difference, then that could be a eg: Windows OS update as changed in some way, or a Video Driver or Monitor driver update has changed in some way, or something else in the OS has changed in some way.
So suggest next if you have been making regular windows system restore points or do regular computer hard-disk images, suggest to try rolling back Windows to an earlier time “when it wasnt blanking” and see if that then works ok.
If that doesn’t then next try “changing video resolutions” and see if that makes any difference as might be your eg: Screen resolution has changed causing it, Or could be you have your Windows desktop “scaled” and not on the default 100%.So check your desktop scaling too.
Failing that I would contact where you got your video card from and speak to their technical support to see if they are aware of any blanking issue with those cards in Windows 10. Also ask them “is there a specific monitor driver” for your card apart from the supplied video driver. Some video card manufacturers supply both apart from the default Windows monitor driver.
Also contact Microsoft technical support to see if there is anything in the OS as far as eg: power management etc that could be causing it.
Lastly with that new Ryzen 9 CPU, you should really now be eg: looking as well at upgrading to Windows 11 being Windows 10 is end of life soon for security updates. Upgrading to Windows 11 “might also fix that issue” with a Win 11 Video driver for your specific GTX 1660 Super card.
I do have a paid license, but I don’t subscribe to their yearly “VIP Support”, so the support I did get with that older “Pro” license has long since expired.
You can extend that for another 12 months via the following page below.
“Get a 1-year extension to your VIP Support”
https://www.emclient.com/extend-support
