I prefer having as much of the screen follow the “Dark” theme as possible vs. all the white and other colours in the stock version I edited it.
Unfortunately I haven’t figured out how to fix the “compose” window to follow this theme, but maybe someone will help me figure that out one day!
theme available at this link
https://www.dropbox.com/s/k8vd8g3oaijl9uo/modified_dark_180727.emtheme?dl=0
sample
Gary
July 28, 2018, 6:29am
2
Thanks Dave. I was hoping you would post your theme.
Gary
July 28, 2018, 6:34am
3
When you have it just right, consider adding a thumbnail so it looks pretty in the list.
Courtesy of Shanna :
You can add a thumbnail to a theme by taking a screenshot, using the top left portion, and reducing it to 80x80. Save it as a 24-bit PNG. Run it through tinypng.com , then encode it as base 64 data using this link
http://www.askapache.com/online-tools/base64-image-converter/
Then take only the data portion (after the comma) and put it into the
base64 data here
tag at the bottom of the theme file.
This is quoted from https://forum.emclient.com/emclient/topics/themes-in-em-client
thanks for the tip - I’ll update it when I get a chance - cheers
