Mobile Version: Need icons for Calendar and Contacts (Android)
Just started using the mobile app on Android, finding it frustrating to have to open the calendar by tapping the eM Client icon and then having to click at the top to activate the side menu, and then click the calendar at the bottom. Other mail clients offer widgets/shortcuts that can be added to the homescreen.
Other than that, I do like the app, has a very similar feel to the desktop app.
I can recommend you to put a feature request on Sleekplan here:
Done!
