Can you a feature where if i close the app, it will not fully close. it will be minimized to the windows tray? it would really help a lot.
Thank you
Thank you
Go to “Menu / Settings (Preferences) / General” and tick “Minimize to tray”.
If you do minimize to tray (like also minimize to taskbar), make sure you “completely close eM Client in the tray” before shutting down your computer, or you will normally cause database errors on eM Client reopening / startup.
Or alt “Shut down in Sleep mode” if you like to keep your apps open all the time in the tray to avoid any database errors on computer wakeup.
The one you are looking for is the one checkbox under
‘‘Close application to tray’’
Settings - General - General
