When I reply to an email on my iPhone, it now says ‘Your email will be sent shortly’. And then it just sits in my outbox forever but I cannot SEE it in the outbox. As soon as I come to work or home and are in the Wifi, all messages fly out! It works fine on the computer, the problem is only in the iPhone app.
Sounds like your sim cell data is not working due to maybe a mobile signal problem, or some sort of cell sim data ip problem or maybe no cell data left.
So suggest to “close eM Client” and disable your cell data and disable wifi on your iPhone and then turn your cell data back on (without wifi) and try sending a new email and see if it sends.
If it still won’t send, check your mobile cell signal bars “to make sure you don’t have a low mobile signal problem” causing the sending problem.
If it still wont send and you have good mobile signal bars ok, then “check that you havent run out of your monthly cell data usage” from your mobile provider. As could be no monthly sim / esim data left.
If you still have mobile sim / esim data left, then “try completely powering off & on your iPhone” to force it to reconnect to the nearest mobile tower. Then try sending mail again & see if it sends.
no, thats not the problem, The problem seems to be the port in SMTP, it must be another port
The smtp port is normally the same for cell data or wifi. The only difference can be “your SMTP Server address” but you would normally only manually change that if you want to send out a different mail server. What is your SMTP settings ?
Also can be if your cell / mobile provider “blocks specific smtp ports” so you would have to manually change them but that’s very unusual if they do.
Also if you are running eg: mobile VPNs then that might not work with your cell / mobile smtp server address or server port but might work with a wifi.
