Message stuck in unread and corrupted
Can’t delete or move this message from the standard unread folder, also checked in Outlook and it’s not there. Even deleted the folder this message was in on the email account it was on and while it removed from the email address, it’s still stuck in the Unread folder with the moving email icon. I believe this is because I had a rule set to delete all messages permanently that comes to the inbox with this email title, but for whatever reason this one went wrong.
I don’t want to have to delete and reinstall eM Client because when I do that all my “rules” mess up and for whatever reason all the tagging on each email is forgotten also, unless there’s an alternative to fix that (i.e. downloading every message which isn’t appropriate)
If you carn’t delete or move the message and closing and reopening eM Client and rebooting your computer also makes no difference, and that message “does not appear online in your mailbox”, then try closing eM Client and running the database repair manually via the Command prompt or Terminal. See my post below.
However if that message is showing in the same place online via webmail, then “close eM Client” and delete the message online, and then reopen eM Client which should then remove it locally when eM Client recconects / syncs.
Alternatively if you have been making regular eM Client backups either automatically via the Settings or manually via the Menu, then you can instead try restoring your last recent backup via “Menu / File / Restore” when you didn’t have that message problem & continue on from there.
