Message pane light/dark toggle - make sticky
The light/dark toggle in the message pane can be clicked to toggle from dark mode to light mode or vice versa. When the message page displays the next/prior message, the toggle is reset.
It would be nice if emClient retained the light/dark toggle setting between emails, even better between sessions. This behavior could be disabled by default (to maintain consistency with previous versions) and enabled in Settings.
Thanks.
There is a Sleekplan suggestion you can vote for to have a button that will Toggle the Dark / Light Theme to then not have to manually toggle from dark to light & back through messages.
