I have three separate calendars which I want to merge together so that I have just one calendar. How do I merge them?
Hi, you can’t merge calendars into one, but you can go to the agenda view, select all your calendar events and move them into your another calendar.
Or you can just simply check the checkboxes next to those calendars in the left sidebar and while using the calendar, all items from the checked calendars should be displayed in the calendar view.
Hope this helps,
Many thanks. Just what I needed
Glad I could help, let us know if you come across any other issues or questions, we’ll be happy to help.
