By design, messages moved to Junk are left as unread as that is the only indicator once a message has been moved there. It helps you to identify messages incorrectly identified as spam.
You can re-create the Spam filter Rule to include marking as read, but as spam filtering is usually done by your server, there is not much point.
You need an option button to allow junk to be automatically read (for those many users that want it this way).
Problem is I’m using a different program and the unread icon shows up at bottom of screen so I open email only to find out it is a message in the junk folder. That can be frustrating and a waste of time.
By adding an option then users can have it either way.
Thanks,
Maybe that is something you need to discuss with the people who provide that application, as eM Client does not give notifications for messages in the Junk folder.
Totally agree. It is quite annoying that the spamfolder have a few unread mails that is very, very seldom of interest anyways. Make it happen, please! Should be really easy to implement.
If you don’t want to see the Junk folder, right-click on it and choose Hide.
It will be banished to the More folder, which is collapsed by default when eM Client starts so you won’t see it unless you manually expand the More folder. And unread messages in the Junk folder don’t show in the Favorites Unread folder either, so you won’t ever know they are there. But if you ever need to check for a missing message, it is easy enough to find the Junk folder, and the message may be among those marked as unread.
With some services like Gmail, you can also disable the spam folder for IMAP in the web interface for that account. Then the Junk folder won’t even be seen anywhere in eM Client.
