to set signatures in Outlook for all users I’m running a login script for each user that:
- Looks if a new signature on the file server
- Copies the signature from the file server to
"$env:userprofile\AppData\Roaming\Microsoft\Signatures"
- Sets the registry values in
HKCU:SOFTWARE\Microsoft\Office\16.0\Common\MailSettings
to use the signature by default
Actually this is quite simple
I’d like to do this with em client, too. Where are signatures stored? How can I set a signature via Powershell (registry value, ini-File, …)?
Thanks
Just found this: https://de.emclient.com/docs/eM%20Client%20Deployment%20automation%20guide.pdf
Using this method I can import a new signature, but sadly I cannot change/overwrite an existing signature.
Apparantly I’ve missed this setting inside the signature:
<signature name=“My Signature” allow-edit=“false” overwrite=“true”>
Setting overwrite to true enables overwriting of the signature.
Gary
4
You solved it all on your own and gave others some very useful information.
It is a very specialized requirement, but someone will search the forum and find this, and be very happy.
Thanks for that.
