I tried double-clicking a column header divider to make the column width auto-size to the contents, but it didn’t. This is true for the Mail and Contacts default views, I haven’t tried it elsewhere.
In other apps, I find this a better way of resizing columns than dragging the divider manually. I always try double-clicking the divider first, then adjust it afterwards.
To reproduce:
- Open eM Client in the Mail view
- Hover over a column header divider, e.g. the right-hand edge of the Received column header.
- The pointer will change to a Horizontal Resize shape.
- Double click.
- Nothing happens.
What I expect to happen:
- Now open your Documents folder in Explorer and change it to Details view.
- Hover over a column header divider, e.g. the right-hand edge of the Name column.
- The pointer will change to a Column Resize shape (note this is different to the eM Client behavior in step 3 above)
- Double click
- The column resizes to fit the contents.
See http://msdn.microsoft.com/en-us/libra… for examples of the pointer shapes described above.
