Hi John,
the person on the Softmaker website is just showing the settings he made in 3 screen shots.
Although I would also connect ‘e-mail senden’ under ‘MAPI’ to eM Client.
Hi John,
Thank you for this clarification.
Jan
Nope, still broken with me…
eM Client 6.0.19861.0
I will express myself tomorrow.
Regards
I`m use eMClient here in Germany as a bundle with SoftMaker Office 2012, a great alternative to Microsoft Office. My problem is the same as you. A few months ago I switched from Chrome (without our problem) to Firefox ( with our problem). A few days ago I had clean installed my laptop with Windows 7/64, the driver and eMClient. I thought that version 6 brings help. But it is not so. I’ve tried some things, without realy help. I can not say which step brought the help .Please turn in Picture 3 on “Non-Microsoft” and / or " Microsoft Windows". Then reboot Windows and sit again “Custom” with the hook set. I hope it helps some. Sorry, my English is not realy good, but I hope, anyone can use this.
Hi Waldy,
I tried your suggestion and it did solve my problem:
Thanks!
I`m glad that I could help. Perhaps the programmers can fix the problem now.
Hi, unfortunately from our side it is not technically possible to do more than we are doing at this moment.
Jan
I solved by adding this to the windows registry: (Windows 7 64bit)
[HKEY_CLASSES_ROOT\mailto]
@=“eM Client URL”
“URL Protocol”=""
[HKEY_CLASSES_ROOT\mailto\DefaultIcon]
@=“C:\Program Files (x86)\eM Client\MailClient.exe”
[HKEY_CLASSES_ROOT\mailto\shell]
[HKEY_CLASSES_ROOT\mailto\shell\open]
[HKEY_CLASSES_ROOT\mailto\shell\open\command]
@="“C:\Program Files (x86)\eM Client\MailClient.exe” /mailurl “%1"”
For those still having the same issue (I was until a few moments ago): Albert’s solution above does work. If you use regedit to add the values then remove the outer quotes, replace all " with just " and all \ with just a single . For example, under HKEY_CLASSES_ROOT\mailto\shell\open\command create a string value with name @ and value
“C:\Program Files (x86)\eM Client\MailClient.exe” /mailurl “%1”
Then, make sure eM Client is set as the default mail program, restart Firefox, and then in Firefox go to Tools->Options->Applications, find “mailto” and select “Use eM Client (default)”.
