To test the e-mail program with the mail Yandex, I registered a test account:
Web: https://mail.yandex.com/
E-mail: [email protected]
Login: em-client-test
Password: 46Q64z8L57
It describes the settings for the e-mail programs: http://help.yandex.com/mail/access/em…
All information in English. I suggest you now and in the future to use a test account to check the operation of the program.
Tested program: eM Client BETA 6.0.19106
Work on the POP3 protocol:
pop.yandex.com, port 110, dont use secure connection smtp.yandex.com, port 25, dont use secure connection
_ The work program is successful _
Log:
19:04:26 em-client-test (POP3) [POP3] Connecting: To em-client-test (POP3)
19:04:26 em-client-test (POP3) [POP3] Connected: To em-client-test (POP3)
19:04:26 em-client-test (POP3) [POP3] Downloading messages: From em-client-test (POP3)
19:04:26 em-client-test (POP3) [POP3] Disconnected: From em-client-test (POP3)
19:04:26 em-client-test (POP3) [POP3] Disconnected: Done
19:04:49 em-client-test (POP3) [SMTP] Connecting: To em-client-test (POP3)
19:04:49 em-client-test (POP3) [SMTP] Connected: To em-client-test (POP3)
19:04:49 em-client-test (POP3) [SMTP] Sending messages
19:04:50 em-client-test (POP3) [SMTP] Disconnected: From em-client-test (POP3)
19:04:50 em-client-test (POP3) [SMTP] Disconnected: Done
19:05:06 em-client-test (POP3) [POP3] Connecting: To em-client-test (POP3)
19:05:06 em-client-test (POP3) [POP3] Connected: To em-client-test (POP3)
19:05:06 em-client-test (POP3) [POP3] Downloading messages: From em-client-test (POP3)
19:05:06 em-client-test (POP3) [POP3] Disconnected: From em-client-test (POP3)
19:05:06 em-client-test (POP3) [POP3] Disconnected: Done
Work on the POP3 protocol + SSL:
pop.yandex.com, port 995, force usage off SSL/TLS
smtp.yandex.com, port 465, force usage off SSL/TLS
_ The work program is not successful _
Log:
19:09:18 em-client-test (POP3) [SMTP] Connecting: To em-client-test (POP3)
19:09:49 em-client-test (POP3) [SMTP] MailExceptions.SocketException: Connect failed with reason:
19:09:49 "Unable to read data from the transport connection: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера."
19:09:49 at MailClient.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
19:09:49 at MailClient.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
19:09:49 at MailClient.Commands.Command.Process(WorkerStatus status)
Successfully established a connection with these settings:
pop.yandex.com, port 110, force usage off SSL/TLS
smtp.yandex.com, port 587, force usage off SSL/TLS
Not sure if these settings to create an encrypted connection
Log:
19:15:45 em-client-test (POP3) [SMTP] Connecting: To em-client-test (POP3)
19:15:46 em-client-test (POP3) [SMTP] Connected: To em-client-test (POP3)
19:15:46 em-client-test (POP3) [SMTP] Sending messages
19:15:46 em-client-test (POP3) [SMTP] Disconnected: From em-client-test (POP3)
19:15:46 em-client-test (POP3) [SMTP] Disconnected: Done
19:15:46 em-client-test (POP3) [POP3] Connecting: To em-client-test (POP3)
19:15:46 em-client-test (POP3) [POP3] Connected: To em-client-test (POP3)
19:15:47 em-client-test (POP3) [POP3] Downloading messages: From em-client-test (POP3)
19:15:47 em-client-test (POP3) [POP3] Disconnected: From em-client-test (POP3)
19:15:47 em-client-test (POP3) [POP3] Disconnected: Done
Work on the IMAP protocol:
In all combinations of settings connection could not be established.
19:20:52 [email protected] [SMTP] Connecting: To [email protected]
19:21:22 [email protected] [SMTP] MailExceptions.SocketException: Connect failed with reason:
19:21:22 "Unable to read data from the transport connection: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера."
19:21:22 at MailClient.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
19:21:22 at MailClient.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
19:21:22 at MailClient.Commands.Command.Process(WorkerStatus status)
19:22:29 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
19:23:00 [email protected] [IMAP] MailExceptions.ConnectionException: No server response within 30 second timeout. ---\> System.IO.IOException: No server response within 30 second timeout.
19:23:00 at MailClient.Imap.Base.Connection.Connect(Func`1 getStream)
19:23:00 at MailClient.Imap.Base.Connection.Connect(String receiveHost, Int32 receivePort, Boolean explicitSsl)
19:23:00 at MailClient.Imap.ConnectionPoolEntry.Reconnect()
19:23:00 --- End of inner exception stack trace ---
19:23:00 at MailClient.Imap.ConnectionPoolEntry.Connect()
19:23:00 at MailClient.Imap.ConnectionPool.AcquireConnection(Folder mailFolder, Boolean idle)
19:23:00 at MailClient.Imap.ConnectionPool.AcquireStoreConnection()
19:23:00 at MailClient.Imap.ConnectionContext..ctor(ImapAccount account)
19:23:00 at MailClient.Imap.Synchronizer.SynchronizeFoldersCommand.Execute(WorkerStatus status)
19:23:00 at MailClient.Commands.Command.Process(WorkerStatus status)
_____________________________________________
* - Russian translation of the text in the log:
“An attempt to connect was unsuccessful because from another computer in the required time did not properly respond, or has been established connection has failed to respond because of the connected computer”
