Mail Signature Deleting Body Text...
Hello!
I can’t find this frustrating issue (and a solution) on this forum, so maybe it’s just me…
Recently, eMClient has started to delete the final line or two of body text when I add or change a saved signature. This was a little frustrating; however, today virtually the entire body text disappeared, which is really annoying.
“undo typing” has no effect. I have save the message as a draft, in case it can be rescued, but I fear that I have lost 30 minutes’ work.
Any thoughts…?
Dean
lunes 27 julio 2026 :: 1607hrs (UTC +0100)
Hey @DeanUK
I think I had this issue a few years ago, I change the signature to
match the language that I am writing in, and after experimenting
with various settings started using the following that works for me,
I seem to remember it was to do with the position of the signature.
See under Mail >Templates & Signatures.
It’s worth a try to see if it helps.
I also have, under Compose, Automatically save to draft selected
every 3 minutes.
skybat
¡Buena suerte!
Hello skybat,
Many thanks for your quick response. I switch between languages (and work assignments) too.
This is clearly a bug that has not yet been fixed by the eMClient team. While I’m waiting for them to get to it, I will try your work-arounds.
The auto-save to drafts thing shouldn’t be necessary, but it is a very good idea. I wasn’t aware of that feature. I may set it to save every 30 seconds!
Best wishes,
Dean
お時間をくれてありがとうございました。
lunes 27 julio 2026 :: 1722hrs (UTC +0100)
Hey @DeanUK
Good Luck, I gave up trying because thw work around is fine for me.
言語は変えません。署名だけを変えます。日本語とアラビア語は別のコンピューターを使いますが、ヨーロッパ言語はそのまま書きます。
skybat
¡Buena suerte!
